Dynamic block crossing window missing
marymAGTL5
marymAGTL5
Can anyone tell me what the setting is to be able to see the crossing window when in a dynamic block? I set the parameter and then the action. When I go to do the crossing window it only shows as 2 dots. I cannot see how to tweak the window so it encompasses everything I need.
Brock_Olly
What do you mean with crossing window?
Do you mean this blue window when applying an action?
marymAGTL5
YES! min only shows the 2 grip points. I can't see anything else about the crossing box/blue window in image
Is there a setting to be able to see the entire box?
Brock_Olly
This window only appears when you click on an action, for example stretch, then it will show you the selection window it works in.
Try changing BACTIONBARMODE to 0 and click the lightning bolt to see the window.
marymAGTL5
I understand that the box only appears when you click the action item. BACTIONMODE removes the action box (see blue arrow in first image) and changes it to a lighting bolt. the "box/dashed lines" are still missing.
When I test other blocks that have the stretch command, I see the dashed lines for the action box. It seems to be this one particular block that is causing issues. I might just have to redo the block. The second image shows there are no dashed lines connecting the action points.
