Dynamic Block Array - Stretch Issue with Alternating Objects (Track Light)
cclineL37T5
Message 1 of 11
cclineL37T5
We're trying to create a dynamic block of a track light fixture, with alternating track heads (either side) spaced at 2'-0" o/c, linked to a stretch of the track itself. Issue we have, is the array of the alternating heads stops short of the track stretch and we need those track heads to keep repeating to the end. Any tips/ help is much appreciated!
Image attached of issue w/ dwg. of block in question
TY!
Accepted solutions (3)
Replies (10)
Message 2 of 11
h_s_walker
Is the attached what you want?
Howard Walker
Left Handed and Proud
Message 3 of 11
cclineL37T5
Not exactly, it cannot be linked to increment, as the track itself is cut in field to suit so it's not a 2'/4' etc track length, it's custom. Screen shot for reference, we need the array to keep repeating in this example as shown.
Message 4 of 11
j.palmeL29YX
My attempt ...
Jürgen Palme
Message 5 of 11
cclineL37T5
this is working great, thank you! would you be able to give me a run down of how you fixed it?
Message 6 of 11
j.palmeL29YX
[EDIT]:
I forgot to disable the "Show Properties" property. I'd suggest to do that.
And delete the "VisibilityState0". It was used only while designing the block.
Jürgen Palme
Message 7 of 11
h_s_walker
@j.palmeL29YX to be honest as I did in my attempt I would use the same array for both sets of lights eg the first triangle and semicircle light are on Array and the others on Array2
Howard Walker
Message 8 of 11
j.palmeL29YX
This is exactly how test-pa1 is designed (if I understand you right): Array is for the both upper lights and Array2 for the both lower lights.
???  What I'm missing?
Jürgen Palme
Message 9 of 11
h_s_walker
@j.palmeL29YX If the array was attached to both lights when selecting it they will both show up as highlighted. Compare the two images below. The second is mine. On yours you will notice you have Array, Array1, Array2 and Array3
Howard Walker
Message 10 of 11
j.palmeL29YX
@h_s_walker
Do you test the latest block which was attached to post #6?
Perhaps you have still loaded an older block definition in your current test file? Either open directly my dwg file (which contains "authoring elements" [btw I hate these block files]) or you insert it into a new clean file.
Please check again ...
Jürgen Palme
Message 11 of 11
h_s_walker
@j.palmeL29YX Yeah that wasn't your latest version of the drawing. I downloaded the other one at 9:08am
Howard Walker
