Dynamic block array problem
In this project I have a problem with combining the stretch function with the array function.
I am trying too array the wallblocks in the opposite direction (purple) when I am schrinking the length of the window.
Can you help me?
Greatz Louis 🙂
Try this  -> (Attachment)
Hi Cadder,
Thanks for helping mee out!
Is it possible to send mee a tutorial video on how you managed to combine both actions?
Greatz Louis
Draw a line smaller than 160. One of the endpoints must be inside the crossing window for the stretch action.
Than add an Array along path.
At the end (not to see in the video) you can convert the line into a construction line or put it onto an invisible layer.
(I hope the 1 MB attachment is allowed here)
HTH
cadder
h_s_walker
@Anonymous
Have you tried using Screencast? https://knowledge.autodesk.com/community/screencast
This allows you to record what actions you take in AutoCAD and then you can embed the resulting video (when you get emailed the link) into your actual post.
Howard Walker
Left Handed and Proud
