Dynamic block array action with linear parameter
I don't understand what the requirements for which geometry can be included in an Array action that is attached to a linear parameter.
First I create a linear parameter between any two points (I have tried in various spots all over the block to try and understand AutoCADs rules). In the block editor, I will then click the Array action and choose the linear parameter I just created. It then asks you to select the geometries - I select say a circle and press enter - the "select objects" doesn't move on to ask me the "distance between columns (III)" like I would expect - it just stays on "select objects". I then select a rectangle nearby and the command DOES move on.
I cannot understand which geometries this action will allow me to select so that the command will progress and ask me the distance between columns. Is this a bug in my version? Anyone else confused here? I have tried geometries completely within the distance parameter, geometries with one end within and one end without, geometries with the distance parameter exactly at both ends, etc.
I also can't seem to find anyone else confused on this. Maybe I'm just not understanding the array action correctly.
Any insights would be appreciated - thank you
