Draw order
Draw order
Draw order
I can't get draw order to work in 2019. I have a lifetime license and I need this feature. Do I download a different version?
Libbya
Draworder does not display correctly in the 'test block' window but will work correctly when the block is inserted into model space.  This has been the case for several years.  If you have talking about draworder as it relates to objects outside of blocks, then you are posting on the wrong forum.
s.borello
Can you post a sample file for us?
