Display Date based on certain condition
I am working on updating a title block's revision block and I ran into an issue. The end goal is to have the "Date" column update automatically based on the plot date. Currently, I have 6 columns (Rev, Date, Remarks, By, CHK, APPV). Each column (with the exception of the Date column) is set up to using attributes with a field referencing a lookup table. I am trying to come up with a way to have the date column automatically update if the row is being
used. If not, I need it to remain blank. See below for an illustration. I have also attached the block file. As you can see from the photo, my initial thought was to use the fields "PlotDate" feature. However, it would print the date in each row of the of the Date column. I only want the date to be shown if the row is being used. I hope I explained this sufficiently.
