I created a dynamic block with blocktables, visibility, some parameters and actions. (see attachment)
Some move and stretch actions are also provided with associated dimensions.
When I make a change for the first time, the dimension loses the association. With the second change everything is correct. (The same happens when I insert this block again..)
Do you have an explanation for this behavior?
We need the correct behavior from the beginning... we tried to change parameters via C#, but we didn't find a code to solve the problem.
Maybe there is a solution I don't see?
Here is a screenshot how to change the behavior of the block:
