Message 1 of 8
12:38 PM
In compliance with NCS symbols icons, I have created a dynamic block series that has various views available in a single block. Key capabilities:
In standard and boxed view, the symbols offer:
- The attributes can be flipped and/or rotated
- Boxed symbol offers hatch pattern option
- Most offer rotation of the internal symbol (e.g., microphone or speaker)
- Some also offer stretch/scale in standard view
- Alignment of insertion
- Block table option to move settings back to neutral points when going between views
For circle view, the symbols offer:
- Movement of attributes since circle is larger and needs to have center reference from corner in standard or boxed view
- No alignment of insertion
- Some also offer rotation of the internal symbol (e.g., microphone or speaker)
But I need to add a second flip option (in the example, Circle_Flip_Text), but receive the following problems:
- If I go immediately to circle view and flip attributes, the attributes are moved correctly
- If I change flip on Standard view then go to Circle, the attributes are moved correctly
- However, if I flip the Box view then go to circle, the attribtutes become unstable. Then only way to correct them is to delete the block
- I changed the settings to Show properties--but that didn't help
- I added the flips to the Block table to return properties to base points, but flip still don't return if I go to Box then Cirle view
Any assistance would be appreciated.
Also, does anybold have any suggestions to eliminating block table as this is incompatible with LT and other CAD programs. The biggest value is ruturning vaules to base point.
