Diesel expressions in field inside dynamic block
S_S_SS
Message 1 of 9
S_S_SS
Hello every one
I need to make field that appear value if the dimensional constraint have a value bigger than 2000
$(if, $(>, $(getvar, Telescope_Height), 2000), "XB 1.20 m", "")
i try to make it with the diesel as the above
Telescope_Height is the dimensional constraint value
XB 1.20 m   is the field that i need it to appear
but it don't work
can someone help me in this ??
i've made a simple example in the attached DWG
thanks in advance
Replies (8)
Message 2 of 9
h_s_walker
Use a double lookup to change visibility states depending on the length of the parameter. See the attached drawing. The number automatically changes because it's a dimension which is associated with the line.
Howard Walker
Left Handed and Proud
Message 3 of 9
S_S_SS
Thanks sir for your reply
but it's necessary to make it dimensional constraint not linear parameter because i need it to make specific calculations
also I've more and more visibilities and then i must double all these visibilities to make what i need ....
so i see that it's necessary to use the diesel expression ....
Message 4 of 9
h_s_walker
Are these multiple visibilities in one block or multiple blocks? If it's one block you only need one visibility state for the > value.
Howard Walker
Message 5 of 9
S_S_SS
these all the visibilities in one dynamic block
i should make all of them to if the value bigger than 2000
and if it's less than 2000 ??
you can see the attached DWG
THE DIMENSION CONSTRIANT NAME IS Telescope_Height
AND SEE THE FOLLOWIMG FIELD PLACE IN EACH VISIBILITY
CAN HELP ME HOW TO MAKE THIS ??
Message 6 of 9
Libbya
How do you make the telescope_height greater than 2000?  It looks like the largest increment is 1433.
Message 7 of 9
S_S_SS
Yes you are right it was an example to understand what i can do
Make it 833 instead of 2000
Message 8 of 9
Libbya
If all of the specific values are increments, then you can write the attribute value directly using a block properties table or for ranges you could use a lookup not for a visibility state, but just to define the lookup value for the specific range and then use a blockplaceholder field referencing the lookup value.
Message 9 of 9
S_S_SS
okay thanks sir for that
