Custom Dynamic block / Multi-leader for Unique Drawing Style
Hi all,
Thanks everyone for your help in advance. I'm relatively new to AutoCAD and am trying to simplify a workflow and drawing style that I've had to inherit off someone else.
The drawings I typically have to create manually create a speech bubble-like callout (essentially a multi-leader) that has typically have 5 components - two enclosed polylines, two hatches and multi-line text. See the attached screenshot.
Is there any way I can create a dynamic block/multi-leader that can eliminate/reduce the manual nature of adjusting each of these components whenever I want to adjust a callout? Ideally the size of the box would automatically scale to the size of the text and you could select which direction the leader came from.
Any help would be appreciated. Slowly getting into block editing and dynamic blocks so still pretty novice.
