Create pipe block with single snap that adjusts ID/OD for connecting into pits at angles
Engeny_Civil
Message 1 of 1
Engeny_Civil
I am trying to create an underground stormwater pipe block that has the ability to trim/extent the ID/OD from a single snap. Currently the block can extend and rotate from a single snap but i am trying to see if there is a way to modify the ID/OD strings when a pit isn't at 90 degrees to the pipe.
Does anyone have something similar or any ideas?
I have got it half working by just creating a bunch of linear parameters but it creates 4 individual snaps that have to be updated manually.
Screenshot attached:
Blue square snaps = move/rotate the block to the correct alignment
Blue Arrow Snap = extend/trim the 4 yellow lines (pipe ID/OD) to the white line (pit)
Replies (0)
