Crane Dynamic block
Crane Dynamic block
umesh_kawa
Crane Dynamic block
umesh_kawa
Dear all,
I am currently working on creating dynamic blocks for a crawler crane that includes multiple boom lengths. However, I'm facing an issue with boom length adjustment are not functioning inclidng the hook block movement.
Has anyone else experienced this issue or could provide insight into what might be going wrong? I’d appreciate any tips or solutions for the hook block and boom adjust correctly in relation to each other.
Thank you in advance!
umesh_kawa
forgot to missed attachment
K_Kubat
I have repaired your block a little, so it should actually work.
With linked action parameters, only the action can be used, not the objects in other actions, otherwise it will be executed twice. I replaced your action parameter row with an Autocad path row and linked this again with the corresponding actions. The ref. parameter had no linked action and I deleted it.
umesh_kawa
Hi K_Kubat
Thank you for your soluction, i appriciate your help,
Regards
RiggingEngineer
Have a look at this dynamic crane block. It might give you some inspiration
umesh_kawa
Thanks, mate.
It's very large (many parameters) and has lots of information in one block. You really worked hard on this block. I appreciate it as a good reference.
