Crane Dynamic block
Crane Dynamic block
umesh_kawa
Message 1 of 11
Crane Dynamic block
umesh_kawa
Dear all,
I am currently working on creating dynamic blocks for a crawler crane that includes multiple boom lengths. However, I'm facing an issue with boom length adjustment are not functioning inclidng the hook block movement.
Has anyone else experienced this issue or could provide insight into what might be going wrong? I’d appreciate any tips or solutions for the hook block and boom adjust correctly in relation to each other.
Thank you in advance!
Replies (10)
Message 2 of 11
umesh_kawa
forgot to missed attachment
Message 3 of 11
K_Kubat
I have repaired your block a little, so it should actually work.
With linked action parameters, only the action can be used, not the objects in other actions, otherwise it will be executed twice. I replaced your action parameter row with an Autocad path row and linked this again with the corresponding actions. The ref. parameter had no linked action and I deleted it.
Message 4 of 11
umesh_kawa
Hi K_Kubat
Thank you for your soluction, i appriciate your help,
Regards
Message 5 of 11
RiggingEngineer
Have a look at this dynamic crane block. It might give you some inspiration
Message 6 of 11
umesh_kawa
Thanks, mate.
It's very large (many parameters) and has lots of information in one block. You really worked hard on this block. I appreciate it as a good reference.
Message 7 of 11
tylerXDY5A
Hi Mate,
I have been having a look over your block as I need to create something similar for a Kalbeco. however, I am struggling with the array action. I can see the thinking behind what you have done with the point Parameter acting as a trigger to tell AutoCAD when the webbing needs to start copying, I just can seem to get it right. Could you please have a look and maybe even give me an explanation on how you did it?
Very much apricated. Thank you
Message 8 of 11
K_Kubat
Hello tylerXDY5A
I'm not entirely sure what you're trying to create as a repeat.
Here's an example of how it can work:
Create a line for the row path.
Convert this to Construction so it's not visible in the finished block.
Create a path array for your object using this line.
Add the line to the Stretch action or create a new one.
Attached are your block with the suggested pattern and a sample block.
Message 9 of 11
tylerXDY5A
Thank you for your help.
I think I miss understood how the process worked in the original block.
Message 10 of 11
kazimhussain00007
Community Visitor
Community Visitor
Can anyone help me create a dynamic block of the SANY STC700C5 mobile crane? Thanks in advance.
Message 11 of 11
j.palmeL29YX
What do you expect what the requested help should include?
Jürgen Palme
