crane dynamic block - adding bracings
coolkris
Message 1 of 9
coolkris
Dear all,
I need to add bracing as attached in separate 2 cad files.
First one created outline of crane with stretch option.
The second drawings consist of bracing which also need to be added in first block.
Krish
Accepted solutions (3)
Replies (8)
Message 2 of 9
j.palmeL29YX
Maybe something like the attached block "test" (?)
HTH
Jürgen Palme
Message 3 of 9
coolkris
Thanks a lot, that is what a exactly needed and i have one last simple addition if possible.
1) dynamic dimensions and the
2) dynamic chain which remain vertical.
Krish
Message 4 of 9
j.palmeL29YX
@coolkris wrote:
... i have one last simple addition if possible.
1) ...
2) ...
Nevertheless, I attached an example how you can solve the issue.
HTH
Jürgen Palme
Message 5 of 9
coolkris
thanks a lot ! very helpful for me
Message 6 of 9
-Hi please watch my short tutorial on Crane Palette (Demag CC 8800-1) from the link;
https://youtu.be/GaT2nK8wYFg  then give us your follow-on question so we could provide you helpful answers/tips...
Message 7 of 9
coolkris
Can you please send me the file as the corporate network blocked youtube
here.
Krish
Message 8 of 9
Hi Krish,
               Attach video clip, on my old drawing blocks what i am trying to show here is the limitation of "Dynamic Blocks". To attach the bracing's on multi-lengths of boom will be a challenge to the autocad authoring palletes, "POLAR STRETCH" will be your PARAMETERS then "ARRAY" will be your "ACTION" of the selected parameters. The action of your array will be to copy multiple bracing's @ equal distance from point origin ex. if the total length of bracing's is at (x)500mm and your Main Boom is @ (x)4550, then your set's of array will be at 4500 in total length with a total bracing set's of 9 pieces. On the attach screen grab, notice how the bracing's misaligned from the main boom. So i came up on a solution to use a "LOOK-UP PROPERTIES TABLE" to mitigate the challenge "CHAIN ACTION" was not helping.
Programming your crane drawing will be perfect, drawing & calculation will be of the same time "for start you may use" "AUTOCAD & EXCEL".
Message 9 of 9
Crane Drawing Block (Programming Clips) 2D & 3D...
