Controlling Block Visibility with custom drawing properties
SORONW
SORONW
Is there a way to allow for a block visibility state to be managed by a drawing property? We use an external program to manage properties and the question was floated as to whether we could use that to control the state of a block.
Is this even a possibility? or am I barking up the wrong tree?
doben
The visibility can be changed through the properties palette when a block(s) is selected.
SORONW
I'm aware and I defnitely concede that's the simplest solution but I didn't know if there was anything more dynamic than that I could use. We use an external PLM program where we manage these characteristics that are then applied to the document. There are a series of blocks we add to our drawings at certain stages of approval that we are combining into one dynamic block, and we wanted to see if we could make changing between them automatic. It's already company policy to update a field in the external program that is passed to the AutoCAD drawing as a custom drawing property, so I was curious if we could remove a step in needing to manually change block states by reading that property.
lena.talkhina
Hello @SORONW  !
Great to see you here on Dynamic BlocksForum.
Is there any updates on the question in this thread? Don't hesitate to update discussion here so other members would know that you are still looking for a solution.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
