Hello everyone,
I have a dynamic block with a block table with different visibility state, this works fine. But now I want to create an extra separate menu. I have created two linear stretches one is used in a lookup function to display the extra menu and controls the other stretch function which is used in the block table.
The if one stretches one or the other stretch the other one moves with it. The extra possibilities are defined in the block table, if the stretch values are changed the corresponding visibility state isn’t shown, the stretch values do change.
The block has to operate as following: choosing the correct type from the bock table and the lookup function is to decide to show something extra within in the block (the value 10 retains the standard block and the value 20 has to show something extra)
Now the questions are:
- Is this possible to control the block table with action parameters if so can someone point me in the right direction?
- Is it possible to hide the stretch value in the block table so that I can only be chosen from the lookup table?
Thanks in advance!
