Changing Prefix in dimension trough language selection Lookup
s_hendrikxHMCCF
Message 1 of 9
s_hendrikxHMCCF
Hey Guys,
I'm looking for a way to cut down on visibility states in a double lookup block I'm working on but I can't seem to get this to work.
I have 4 language types that represent 4 prefix possibilitys.
DE: Nutzraum
EN: Useful
FR: Utile
NL: Nuttig>
When changing the language in the lookup i want the tekst in the dimension to change.
In the attached block is my last attempt at trying to reach a solution.
Replies (8)
Message 2 of 9
Libbya
Turn off the dim text.  Replace it with an attribute.  For the attribute default value add a blockplaceholder field that references the lookup and then a field that references the dimension value.
Message 3 of 9
s_hendrikxHMCCF
Hey Libbya thank you for your initial reply!
I can't seem to fully grasp how to put this together.
When placing the blockplaceholder field in the ATT I can select the Lookup but i can't let it show the Lookup value that is the text from my first post.
Message 4 of 9
s_hendrikxHMCCF
I think I got it right to some extent. the tekst changes to hashtags when changing the language
Message 5 of 9
Libbya
See attached.  That's what I was thinking.  After making a change to lookup or dim length, do a REGEN to see the change displayed in the field.
Message 6 of 9
s_hendrikxHMCCF
Isn't it possible to keep the measurement reading as standard and place a field like text in front of it?
I know it isn't possible via blockplaceholder but is there no workaround for this?
Message 7 of 9
h_s_walker
@s_hendrikxHMCCF No unfortunately there is no workaround to do it the way you want to do it
Howard Walker
Left Handed and Proud
Message 8 of 9
s_hendrikxHMCCF
That's sad to hear. For now, thanks for the response!
Message 9 of 9
Libbya
The attribute will plot exactly the same as the dim text.  What's the hang up?
