Changing Linear Parameter Distances
I have a dynamic block set up that is using the Linear Parameter + Array Action in order to create a large array of an object.  Over time my client may want to change the dimensions of that object being installed, and/or change the distance between objects.  Is there a way to change the distance between rows and between columns by editing the linear parameter itself?
Thanks in advance for any advice!
Hey,
Changing an array made of dynamic block dynamically is not yet possible.
Your client needs to right click on the array, "Array / Edit source objects in-pace", choose one block, change parameters as required, Save Changes, and then manually grab the grip and put it in the right location.
See picture below, that you change the length and gap dynamically (part 2), but change the array grip manually (part 3).
Cheers,
Thanks for the input! I was hoping that it was possible to change the
array made of dynamic blocks, but that solution seems to be our best bet
for now.
Glad to hear that it was valid 🙂
Cheers
