Change Radius of Arc or PolyArc Without Changing Endpoints
I'm trying to create a dynamic block that allows me to change the radius of an arc or poly-arc without changing the endpoints. Basically, the endpoints will not translate in any direction but the radius will grow or shrink causing the arc to bulge or flatten respectively.
First, I show the issue. Then I show what I need to happen.
vinodkl
The outcome is not possible to achieve with parameters. You need to use constraints to get what your looking for.
See the screencast for better understanding.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
I marked your answer as the solution. Thank you.
For understanding, why would you use parameter/actions vs constraints?
