Change Position of Attribute with 2 Criteria
arkelec
arkelec
Not sure if it's possible to do this.
A Visibility function changes the look of the object accordingly.
Using a Block Properties Table, I control the visibility & the value of the attribute.
A Rotate function & a chained Move rotate the attribute about the centre-point whilst maintaining the text orientation.
What I want to do is to change the base position of the attribute in line with the objects in the visibility state (2 of the 5).  For the 1st 3 vis states, x = 0, y = 150.  For the last 2, x = 0, y = 300.
I tried using co-ords of the Position function in the Block Prop Table.
Nope.
ojuris
Look at this
h_s_walker
Worked fine for me. See the attached drawing
Howard Walker
Left Handed and Proud
arkelec
Cheers @ojuris.
I tried using a distance, but didn't couple it with scale. Also had it on the wrong axis.
Doh!!
