Message 1 of 9
Hi
I have a setup, where i can insert a lot of objects, including dynamic blocks, but is there any way to change the parameters, using only keyboard (because of scripting)?
Eg i want to change the Distance parameter from the 1000 mm to 4320 mm.
I know i can grab the arrow, and drag it, but I dont want to use the mouse, because I have a setup, where all of the blocks are inserted in the correct place, and rotation, but I can figure out to chang the parameter, in my work file (not the one where the Dynamic block is made).
I hope it makes sense 🙂
