Centring parameter grips after stretch
tonyduckworth_94
tonyduckworth_94
I have a block with individual stretch actions for the both heights and widths (2 for each top/ bottom and left/right), in the centre I have a text attribute for a room name, which centres within the area ok.
the issue i have is the parameter grips for the width and heights do not centre as the height or widths are changes, so are stuck in the original positions, i cant figure out what actions to add tot he grips to make them centre as the widths and height changes
Any assistance most welcome
tony.
j.palmeL29YX
The short answer:
Add the parameter (which you want to stay centered) and its grips to the selection set of the move actions.
Try the attached suggestion.
Jürgen Palme
tonyduckworth_94
 j.palmeL29YX
brilliant thankyou, i was trying with the move actions, but couldn't quite get it there, also your solution is a lot tidier combining the actions with the stretch.
thank you.
