Cannot View Attribute Text Outside of Block Editor
I am having trouble getting my lookup parameter to display properly after I have exited block editor. My aim is to create a revision block that allows me to use a predetermined set of callouts without having to type them in each time. I created an attribute and then linked the attribute to a lookup parameter, using the "BlockPlaceholder" field property. When I test it in the test block, it seems to work as I intended, however, once I exit the block editor, the field does not appear. The drop-down appears but the text doesn't. See below for an illustration of the problem.
 Test Block Version works fine!Test Block Version works fine!Text doesn't appear after I exit block editor.Text doesn't appear after I exit block editor.
Libbya
Why two identical threads?  As I just posted in the other one... ATTSYNC, dynamic action, REGEN?  Post block file.
Apologies. I am new to this forum. I thought I accidentally deleted the
initial thread I sent.
Libbya
As posted in the other thread, the attribute value in the existing block is blank.  Delete that insertion and insert the block again.  The attribute field will then show up fine.
