Bursting dynamic block with attributes and visibility states
Hello folks,
I have some dynamic blocks with 3 different visibility states and attributes inside it, and those attributes uses other attributes to make calculations (subtractions) using calculated fields for that task. This is how it looks like in Acad drawings:
Before sending to anyone the drawings, I always explode the dynamic blocks to convert them back to basic autocad entities like "DTexts", lines, and so on. But, by using the "BURST" command, I'm always getting doubled texts like this:
Is this related to visibility states or hidden attributes/fields/calculated fields? Is there any way to explode the block and only get the information that is being showed on screen before exploding the block? Is there any way to prevent this extra information from other visibility states to appear after exploding the dynamic blocks?
Thanks for any help.
fkp7057
check below link from lee-mac this is what exactly you need.
http://www.lee-mac.com/upgradedburst.html
this is lsp program you need to give appload command and load this lsp file select block and give Myburst command.
FKP
;;------------------------=={ Burst Upgraded }==------------------------;;
;;  This program operates in much the same way as the familiar          ;;
;;  Express Tools' Burst command, however invisible block attributes    ;;
;;  are not displayed with the resulting exploded components.           ;;
;;  Following a valid selection of blocks to burst, the program         ;;
;;  converts all visible single-line & multi-line attributes into Text  ;;
;;  and MText respectively, before proceeding to explode the block,     ;;
;;  and deleting the original attribute objects.                        ;;
;;  The core function accepts a selection set argument and may hence    ;;
;;  be called from within other custom programs to burst all blocks     ;;
;;  in a supplied selection set.                                        ;;
;;  The methods used by the program should also perform much faster &   ;;
;;  more efficiently than those used by the Express Tools' Burst.lsp.   ;;
;;  Author:  Lee Mac, Copyright © 2010  -  www.lee-mac.com              ;;
;;  Version 1.0    -    2010-11-25                                      ;;
;;  - First release.                                                    ;;
;;  Version 1.1    -    2013-08-29                                      ;;
;;  - Program entirely rewritten.                                       ;;
;;  Version 1.2    -    2014-02-23                                      ;;
;;  - Program restructured to accept selection set argument.            ;;
;;  - Program now also explodes non-attributed blocks.                  ;;
;;  Version 1.3    -    2015-10-31                                      ;;
;;  - Program modified to account for non-uniformly scaled blocks.      ;;
;;  - Command syntax changed to 'myburst'.                              ;;
(defun c:myburst nil
    (LM:startundo (LM:acdoc))
    (LM:burst
        (LM:ssget "\nSelect blocks to burst: "
            (list "_:L"
                (append '((0 . "INSERT"))
                        (lambda ( / def lst )
                            (while (setq def (tblnext "block" (null def)))
                                (if (= 4 (logand 4 (cdr (assoc 70 def))))
                                    (setq lst (vl-list* "," (cdr (assoc 2 def)) lst))
                            (if lst (list '(-4 . "<NOT") (cons 2 (apply 'strcat (cdr lst))) '(-4 . "NOT>")))
                    (if (= 1 (getvar 'cvport))
                        (list (cons 410 (getvar 'ctab)))
                       '((410 . "Model"))
    (LM:endundo (LM:acdoc))
    (princ)
(defun LM:burst ( sel / cmd col ent idx lay lin lst obj qaf tmp )
    (if (= 'pickset (type sel))
        (repeat (setq idx (sslength sel))
            (setq obj (vlax-ename->vla-object (ssname sel (setq	idx (1- idx))))
                  lay (vla-get-layer obj)
                  col (vla-get-color obj)
                  lin (vla-get-linetype obj)
            (if (and (= "AcDbBlockReference" (vla-get-objectname obj))
                     (vlax-write-enabled-p obj)
                     (or (and (LM:usblock-p obj)
                              (not (vl-catch-all-error-p (setq lst (vl-catch-all-apply 'vlax-invoke (list obj 'explode)))))
                         (progn
                             (setq tmp (vla-copy obj)
                                   ent (LM:entlast)
                                   cmd (getvar 'cmdecho)
                                   qaf (getvar 'qaflags)
                             (setvar 'cmdecho 0)
                             (setvar 'qaflags 0)
                             (vl-cmdf "_.explode" (vlax-vla-object->ename tmp))
                             (setvar 'qaflags qaf)
                             (setvar 'cmdecho cmd)
                             (while (setq ent (entnext ent))
                                 (setq lst (cons (vlax-ename->vla-object ent) lst))
                             lst
                (progn
                    (foreach att (vlax-invoke obj 'getattributes)
                        (if (vlax-write-enabled-p att)
                            (progn
                                (if (= "0" (vla-get-layer att))
                                    (vla-put-layer att lay)
                                (if (= acbyblock (vla-get-color att))
                                    (vla-put-color att col)
                                (if (= "byblock" (strcase (vla-get-linetype att) t))
                                    (vla-put-linetype att lin)
                        (if (= :vlax-false (vla-get-invisible att))
                            (   (if (and (vlax-property-available-p att 'mtextattribute) (= :vlax-true (vla-get-mtextattribute att)))
                                    LM:burst:matt2mtext
                                    LM:burst:att2text
                                (entget (vlax-vla-object->ename att))
                    (foreach new lst
                        (if (vlax-write-enabled-p new)
                            (if (= "AcDbAttributeDefinition" (vla-get-objectname new))
                                (vla-delete new)
                                (progn
                                    (if (= "0" (vla-get-layer new))
                                        (vla-put-layer new lay)
                                    (if (= acbyblock (vla-get-color new))
                                        (vla-put-color new col)
                                    (if (= "byblock" (strcase (vla-get-linetype new) t))
                                        (vla-put-linetype new lin)
                    (vla-delete obj)
    (princ)
(defun LM:burst:removepairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (member (car x) itm)) lst)
(defun LM:burst:remove1stpairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (if (member (car x) itm) (progn (setq itm (vl-remove (car x) itm)) t))) lst)
(defun LM:burst:att2text ( enx )
    (entmakex
        (append '((0 . "TEXT"))
            (LM:burst:removepairs '(000 002 070 074 100 280)
                (subst (cons 73 (cdr (assoc 74 enx))) (assoc 74 enx) enx)
(defun LM:burst:matt2mtext ( enx )
    (entmakex
        (append '((0 . "MTEXT") (100 . "AcDbEntity") (100 . "AcDbMText"))
            (LM:burst:remove1stpairs  '(001 007 010 011 040 041 050 071 072 073 210)
                (LM:burst:removepairs '(000 002 042 043 051 070 074 100 101 102 280 330 360) enx)
;; Uniformly Scaled Block  -  Lee Mac
;; Returns T if the supplied VLA Block Reference is uniformly scaled
;; obj - [vla] VLA Block Reference
(defun LM:usblock-p ( obj / s )
    (if (vlax-property-available-p obj 'xeffectivescalefactor)
        (setq s "effectivescalefactor")
        (setq s "scalefactor")
    (eval
        (list 'defun 'LM:usblock-p '( obj )
            (list 'and
                (list 'equal
                    (list 'vlax-get-property 'obj (strcat "x" s))
                    (list 'vlax-get-property 'obj (strcat "y" s))
                    1e-8
                (list 'equal
                    (list 'vlax-get-property 'obj (strcat "z" s))
                    1e-8
    (LM:usblock-p obj)
;; entlast  -  Lee Mac
;; A wrapper for the entlast function to return the last subentity in the database
(defun LM:entlast ( / ent tmp )
    (setq ent (entlast))
    (while (setq tmp (entnext ent)) (setq ent tmp))
    ent
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com) (princ)
;;                             End of File                              ;;
Just what I was looking for! Thanks a zillion for sharing this LISP and tip...
kloe.kegels
Nice!
it doesn't completely transfer everything.
My drawing order got mixed up a bit with some hatches and wipeout.
But a "select similar" and then "bring objects to back" did the trick mostly.
Thank you!
Should another burst lisp code exist that fixes the drawing order as well please share!
thanks
error when block contain array
krazeymike
I'm just wondering if this lisp can be tweaked so that the burst blocks keep their respective layers, rather than reverting back to layer 0.
For blocks that are designed to work 'By Layer' in the drawing.
Thanks in advance 🙂
