Both dynamic text and move action with dropdown list
mauri.land
mauri.land
Hi everyone,
I created a dynamic block for a pipe: I can stretch the length with a snap and also I can change the diameter by a dropdown list in which I setted the values in millimeters and the text in the dropdown list in inches. I would like to add an attribute to show the inches measure in a text in the center of the pipe, but if I try to set it, I can't use the same parameter that I use to change the diameter (it only let me select the length). So the question is: is it possible to use the same dropdown list to change the diameter and the text attribute?
Thank you in advance!
Libbya
Yes, it is possible using either a block properties table or lookups.
mauri.land
Thank you for your reply, can you please explain me?
