Block Properties Table help
Sujan.Maharjan
Sujan.Maharjan
How do I create this test block in a manner in block properties table.
4-R-1
       2
      3
4-I-1
     2
     3 ...
And How does the highlighted portion values work like. Anyone have example blocks?
"Revit Lies in the tension between what we want to do and what can be done!"
Libbya
Your initial values for the user parameters must match a row of the table in order for the check box to work.  See screencast.
Sujan.Maharjan
Thank you.Can I control the output name here without changing visibility name? And What's the difference if I tick (block properties must match a row in the table) or not? And what does that Expression value do?
