block attributes
block attributes
Message 1 of 1
block attributes
H,
I've created a block with multiple attributes that will be shown on our block cable diagram, but i'm wondering if it is possible to have one attribute change automatically, based upon a different attribute.
for example:
if the cable prefix is "A1", then the following attribute will need to say "-W."
if the cable prefix is "EDM", then the following attribute will need to say ".CC."
if the cable prefix is "RAD", then the following attribute will need to say "-"
Is it possible to use a block table and then a field in an attribute to do this?
If not, how would this be done, if it is indeed possible?
I have attached the .dwg file
Chris
Replies (0)
