Automatically adjust stretch based on variable text length attributes
mike
mike
I'm trying to create a dynamic block that looks like the attached image.  It would have three editable text attributes (separated by the vertical lines in the attached image) that can be any length.  I would like the block to automatically adjust size (I'm assuming with stretch parameter/action) based on the length of each of the three text attributes.  So that would mean the overall block would need to adjust length, and the vertical separation lines would need to move.  Can someone let me know if this is possible, and if so, get me started down the right path?  Thanks.
h_s_walker
Unfortunately not. There is no way to adjust lines based on the length of text/mtext objects in a block.
Howard Walker
Left Handed and Proud
mike
That's a bummer.  AutoCAD is essentially already doing it with their "Text Frame" functionality.
h_s_walker
Yeah the text frame can work, but it only does rectangles. There is a lisp somewhere which does rounded rectangles, but there's nothing which can do the shapes you want and for them to stretch with the text
Howard Walker
