Hi
I have a dynamic block of a grid which has a stretch action on the x and y axis'.
I have applied a nested block on an array action connected to the individual stretch actions, in order to count automatically at increments.
I followed the thread "auto-number array in dynamic block" to do it but I have gone wrong somewhere and I cant work out where.
Problems with Block:
1. the automatic count is not working
2. the numbers don't array to the ends
Is there anyone that can help please?
Also, ( I know I am probably getting ahead of myself here) in addition to this I would like the block to be able to stretch from the corner point, doing both axis at the same time and still have the numbers to update. Is this even possible?
Would really appreciate any pointers - file attached with how far I have got
Dee
Solved by Libbya. Go to Solution.
Each of your number fields is a formula field. That formula is a formula field divided by 20. That nested formula is 0/20. 0/20 is always 0 so the outer formula of 0/20 is also always 0. For the nested formula you would need to have blockplaceholder position field divided appropriately to give the value you would like to see for a given position.
