Attribute Text mirroring
So I created dynamic blocks with attribute text and I've noticed that when I load the block into some drawings, the text will mirror and I am trying to keep it from mirroring. MirrorSync command does not work either. In some drawings the block works and other drawings the block doesn't. How do I fix this?
pendean
Community Legend
Community Legend
You inserted them upside down (or your model is), or your the STYLE used to define the attribute text is set to be reversed/upside down.
vinodkl
There is no command such as "MIRRORSYNC" in autocad. Are you using AutoCAD or some other software?
Try using command "ATTSYNC" to update the attributes in the block and inorder to maintain the attribute text not to mirror you need to set the system variable "MIRRTEXT" to "0".
See if this works for you.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
My bad I meant ATTSYNC. But that does not work, and the MIRRTEXT is already set to 0. The block still mirrors when I do not want it to.
vinodkl
Try to "PURGE" the drawing into which the block is being inserted and see if that makes any difference. If it doesn't help please Attach the block so that I can help you.
BTW are you sure your using ATTRIBUTE or just MTEXT?
