Attribute Field Error after inserting a block
kamil_pajakH724R
Message 1 of 8
kamil_pajakH724R
I created a block that counts the length of an array. I did it using an attribute and a field. So far, it's been fine. The problem starts when I insert the block into another drawing using the block library's insert. After inserting, "###" appears instead of a value, and I have to set the field again. Is there a way to avoid having to update it each time?
There's of course the option of using plain text to insert the field, but there's a problem with mirroring it. Then it also mirrors the text. Therefore, I'd really like to stick with the attribute, but I don't want to set it every time I insert it into a new drawing.
Replies (7)
Message 2 of 8
Moshe-A
@kamil_pajakH724R hi,
i tried to simulate the issue and did not had a problem but if you were post your file i could check anyway a field that shows #### means the property field is not available, does that put you in direction?
Moshe
Message 3 of 8
kamil_pajakH724R
I'm attaching the video and file. The block at the beginning of the video is created and everything is fine. When I insert the second one, it shows ###
Message 4 of 8
Moshe-A
@kamil_pajakH724R ,
first for your knowledge 😀 the wonder of dynamic block is found in the block reference\insert (not in block definition)
in the first insert, the the link to linear parameter "distance1" is done on the attribute and each insert you have to
define it again for each insert. what you specified in the block definition is no use for the block reference\insert
does that answers your issue?
Moshe
Message 5 of 8
kamil_pajakH724R
Thanks for the clarification. It doesn’t solve my problem, but it helps me understand it. How can I make it work then?
Message 6 of 8
Moshe-A
@kamil_pajakH724R ,
Well some time understanding the problem is 50% a way from solution 😀
if setting each insert is not a solution then what solution you are expecting?
Moshe
Message 7 of 8
kamil_pajakH724R
I just don't want to have to reset the field every time I insert a block.
Message 8 of 8
kamil_pajakH724R
Okay, I don't know if this is what you meant, but I set the field reference not to the parameter but to the line length and now it works. Thank you!
