Array path with a dynamic block
nillisa2000
nillisa2000
I created a dynamic block for a din rail with holes. The issue I'm having, the holes will remain in sight when I reduce the length of the din rail.
I tried using array action but that seems to add an extra hole after the length of the din rail.
Looking for help, please.  I attached the drawing
MMcCall402
Recreate the arraypath, but first, shorten the line used for the path such that it starts where you want the array to start.  Draw in a new line to patch up the gap left from moving the start point of the line/path.
The objects are arrayed based on their relationship to the beginning of the object used as the array's path.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
MMcCall402
Another option would be to draw in a new line and use it just for the path of the array.  Set that line to be a construction line so it will only be visible in the block editor.
Yet another option, just use an array action with the current linear parameter.  Simple. Cleaner.
Mark Mccall
CAD Mangler
