Array in dynamic block
Vlalo
Vlalo
I cant get working array and dynamic block together that I would have ability to have allthe stretch and move actions available same time with array functions, specially row spacing and column spacing to be modifiable.
Visualisation is attached what I want to have. I also tried to build array into the block with the array parameter but I cant change row/column spacing. It's built in the parameter and can be modified only inside the block. Picture is to demonstrate what funcions has to be available same time.
MMcCall402
You could use a few User Parameters to make the array values within the block accessible from outside the block.  In the attached block I made 4 user parameters. (Rows, Columns, Row_Spacing and Column_Spacing)  I typed the name of these parameters into the properties of the array.  The User Parameters can be edited in the properties window of the block after its been placed in the drawing and it will alter the array within the block.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
MMcCall402
Another way to get the row and column spacing into the block would be to add a couple construction lines with a couple linear constraints.  The names of these constraints can be entered as the values for the array spacings.  Moving the constraint's grip with change its value and that value will be passed on the the array within the block.
Mark Mccall
CAD Mangler
Vlalo
Thank you for solutions, they works as inteded, I struggle to create those user parameters myself, how do you link it with array exactly? When I just create it from parameter manager, there is no link really.
Vlalo
Okay, I found the trick, got it working. Image for others if wondering how.
MMcCall402
Now you've got it!   Its hard to see how its been set up in a finished block as the value of the user parameter immediately takes the place of the parameter name after its entered into the cell for the array.
Mark Mccall
CAD Mangler
