Array Dynamic Block
Array Dynamic Block
m_storry
Array Dynamic Block
m_storry
Hi guys'
I have a dynamic block that is constrained to 2 different handles to produce various sizes. I would like to array the block horizontally and vertically corresponding to the size i pick on the handles, is there a work around?
Attached is the file in question.
Thanks in advance,
Mark........
j.palmeL29YX
What about the vertical distance of the arrayed frames?
Jürgen Palme
m_storry
Hi J,
The distance would vary too.
j.palmeL29YX
AFAIK that's not possible in AutoCAD's Dynamic Blocks. You must "arrange" the frames manually using the ARRAY command.
Jürgen Palme
m_storry
Bugger.................
