Array Dynamic block Distance between columns
Good day
I am trying to make a dynamic block for a circle.
1. I want the circle to have a diameter constraint parameter(which I can adjust)
2.I want to ad an array to the circle as well, so when I adjust nr.1 I can also manually adjust the distance between array columns.
Would this be possible??
Atm it seems the distance between array columns is a fix distance that I cannot adjust?
Meaning the dynamic circle need to be able to adjust dia. and then array it to the adjust dia distance.
(array only in a vertical plane)
Any input would be greatly help full.
Thanks all in advance.
