Array associative hatch
See attached dwg. I have a middle line in my block that may vary in thickness. (use the bottom pull down grip, example #8 vert). I used a stretch right and left parameter to adjust the width of the outline and filled it with an associative hatch. When I array this, the outline changes, but the hatch reverts back to the original width. Any suggestions? I'd prefer not to create visibility states for this. Thanks in advance
Libbya
It's a bug I've known about for some time.  Just select and deselect the array grip and the hatches will all update.  I don't have a better solution.
