Array action in new dynamic block doesn't work.
Chatsie
Chatsie
Hello anyone.
I am a happy user from dynamic blocks.  I am making a new one, a roof curb.
There is a threaded rod inside a concrete filling.  Now I added a distance parameter to one threadsection of the rod.
And I gave an array action to this parameter. When I test out this block, the arrayaction doen't work.  I tested out existing dynamic blocks with arrayactions in them.  They work all fine.  I tried to make some verry simple ones.  Same restul it doen't work.
Also strange in het block, when closed the item that should be copied, has disappeared.  When I open the block it is there, in the right position.
Dynamic block in attachment.
j.palmeL29YX
Try the attached example.
[Edited] to rev. 1
Jürgen Palme
