Alignment atribute with visibility
Hi all,
please, is possible align atribute with visibility?
Example:
Visibility 1: Atribut is align down center
Visibility 2: Atribut is align top center
Thank you and have a nice day 🙂
Welcome to the forums!
I like the idea you have and I'm not sure if there is a good way to do this.
I've attached a block that works for what you want but there might be a better way to perform this task. I know my block doesn't use the same justification that you mentioned, but it still serves its purpose.
With this block, only edit the "Contents" attribute, and then regenerate your drawing, and the text within both visibility states will update.
Hope this helps!
