Message 1 of 8
I have a block that uses an Attribute definition to create tags from target objects. How do I add a space and suffix to to the attribute so it will read as "1200 GPM". the numeric comes from info in another block, and the GPM is the suffix. Attached is an image of the block and language in the Attribute that allows it to pull the Target object info.
