Add suffix to Dimension text in block
jaggisingh003
jaggisingh003
hello,.
i want a lisp to add suffix "(A)", "(B)", "(C)" to block Dimension text.
i found a code by lee mac for find replace text.
but it replace text in all blocks in drawing.
Code  :-
(defun c:SDReplace ( / _StringSubst old new doc ) (vl-load-com)
;; © Lee Mac 2011
(defun _StringSubst ( new old str / i l ) (setq i 0 l (strlen new))
(while
(and
(< i (strlen str))
(setq i (vl-string-search old str i))
(setq str (vl-string-subst new old str i) i (+ i l))
str
(setq old (getstring t "\nFind What: "))
(setq new (getstring t "\nReplace With: "))
(vlax-for block
(vla-get-blocks
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if
(and
(eq :vlax-false (vla-get-isXref block))
(eq :vlax-false (vla-get-isLayout block))
(vlax-for obj block
(if (wcmatch (vla-get-objectname obj) "AcDb*Text")
(vla-put-TextString obj (_StringSubst new old (vla-get-TextString obj)))
(vla-regen doc acActiveViewport)
(princ)
Please help for this code replace selected block Dimension Text only.
Sorry for my English  🙂
fkp7057
@jaggisingh003  you dont need any code & .lsp file it can be done using Auto cad dimension style setting
refer below screen cast you will get idea how its work. hope it will help you. cheers...
Click on Accept solution if its solves your problem.
jaggisingh003
Thanks, for this but this is not the Solution i want.
your block is used only one time in Drawing I have to using the same block in all drawing with different dimension and with different Suffix.
fkp7057
you can use this block as multiple time & if you are using same block in different-different drawing with another prefix-suffix you just need to update dimension style as per your requirement.
