DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Trying to scale a drawing.
2 REPLIES 2
977 Views, 2 Replies
My name is Matthew and it's been about 7 years since I messed with Autocad. I'm trying to duplicate a drawing and when I try to put in the dimensions I have to zoom in real close to see the numbers. What am I doing wrong? I messed with the Annotation scale option at the bottom of the screen but I still can't see the dimensions.
2 REPLIES 2
rkmcswain
I suspect you are in the wrong forum. Are you actually using AutoCAD?
@Discussion_Admin - you might have to move this
To answer your question, you should be drawing things full size, at 1:1. Then after you decide what paper size you want, you can adjust the annotation scale to make the text come out at a certain printed height (the actual size you'll measure on paper).
R.K. McSwain     | CADpanacea | on twitter
Emmsleys
Are you using AutoCAD? If so what release and on what system?
Did you mean to post this on the AutoCAD Forum Board?
Sarah Emmsley
Technical Support Specialist
