Truview 2024 conversion
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
A client using R14 sent me a DWG file, a topographic map with just contour lines. The file was 34MEG. The header in the file said it was version AC032, whatever that may be (2018-2024??). I loaded it into Truview and got the message "This DWG file was saved by an application that was not developed by Autodesk. What do you want to do?" I continued and converted the file to R14. Now the file is 120 MEG. I loaded it into R14 and found that each contour line was an individual BLOCK. I exploded all the contour line BLOCKs, did a purge, and saved the file. Now it is still 119 MEG. I then did a WBLOCK exporting just the contour lines and created a new DWG file, but that did not reduce the file size. The only entities in the file are POLYLINEs. Is there some reason that the R14 file is so much larger than the AC032 file?
