DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
TrueView 2017 - Measuring Area
2 REPLIES 2
17943 Views, 2 Replies
Good Evening,
Would like to know how to measure the areas in TrueView "2017" as I have spent lots of time but could not figure it out.
I have a dwg file, and there are chalets.
They chalets are rectangular shapes.
If I use the "Distance" and I measure X & Y which they are 7100 & 5600 with applying the formula, I will get 39760000 mm2.
However, while using "Area" and select the area by 4 points, it gives "Area = 636, Perimeter = 102" !
Will be heighly appreciated if you can assist/support and explain on how to solve this issue.
BR
Jack
2 REPLIES 2
pendean
in reply to: pendean
Dear Mr. Pendean,
Thank you for your reply and supporting.
It works successfully by just clicking on [model].
Appreciate your kind support and wish you all the best.
BR
Jack
Tags (1)
