Good Evening,
Would like to know how to measure the areas in TrueView "2017" as I have spent lots of time but could not figure it out.
I have a dwg file, and there are chalets.
They chalets are rectangular shapes.
If I use the "Distance" and I measure X & Y which they are 7100 & 5600 with applying the formula, I will get 39760000 mm2.
However, while using "Area" and select the area by 4 points, it gives "Area = 636, Perimeter = 102" !
Will be heighly appreciated if you can assist/support and explain on how to solve this issue.
BR
Jack
Solved by pendean. Go to Solution.
Dear Mr. Pendean,
Thank you for your reply and supporting.
It works successfully by just clicking on [model].
Appreciate your kind support and wish you all the best.
BR
Jack
