I have no problems using True View on PCs, but in our virtual envinment some fonts are being substituted. The fonts in question have been installed manually into the Font folder of virtual PCs.
The RDS virtual environment uses a powerful computer to easily run True View. But rendering is a problem with fonts being substited.
Any ideas or experiences please?
Solved by DrawIT. Go to Solution.
So it looks like Trueview runs perfectly in virtualised invironments for everyone but me.
Or maybe nobody runs it on a virtual PC session.
Not a busy place then. I found out the problem. Someone had not installed a Post Script font correctly. You must install these by right cliking the font files and select Install, not drag and drop them into Windows Fonts.
All working now.
