DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
True view is recomputing hatch boundaries after opening a dxf
4 REPLIES 4
NikhilPundir
208 Views, 4 Replies
I have a dxf (that I cannot share) which contains a hatch. The hatch is associative. It has 3 arcs as boundary edges and the associated entity is 1 polyline.  The arcs do not represent polyline correctly.
So when I open the diagram the dxf in true view, it initially shows incorrect hatch for 1 sec but then recomputes the hatch boundary and shows correct hatch (correct boundary is the polyline)
My initial guess was that because hatch is marked as associative the true view is recomputing it. So, I created another test file and made hatch associative and changed the boundary. But now when I open test file in true view it is not updating to new boundary.
Is there any system variable or flag that is causing the hatch to be recomputed?
Tags (2)
4 REPLIES 4
NikhilPundir
in reply to: NikhilPundir
pendean
What year version of DTV are you using?
On which OS?
DXF files are always slow to load, could that just be the problem? It's very common. But... DWGTRUEVIEW's limited settings option are found in that program's OPTIONS only.
Autodesk recommends you use their free online service instead for this type of task, here is the link
https://viewer.autodesk.com/
NikhilPundir
True View 2024, Windows
I checked the hatch boundaries in dxf code and the hatch boundaries has 3 arcs that make a circle but the hatch also has polyline as entity reference. When the dxf loads, it fills the 3 arcs but then updates and fill the polyline.
NikhilPundir
I cannot upload diagram online or anywhere else
