DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
text wrong displayed and printed with the letters overlapped
10 REPLIES 10
Message 1 of 11
docucenter
604 Views, 10 Replies
Hello.
I have downloaded DWG Trueview 2017 on 32 and 64 system and in both situation the text is misinterpreted and shown overlapped as in attach file. Does anybody know what is wrong?
Tags (2)
10 REPLIES 10
Message 2 of 11
pendean
in reply to: docucenter
The problem is the file, or unique font in the file: nothing to do with the program.
Can you post the DWG file shown in the screenshot?
Message 3 of 11
docucenter
in reply to: pendean
Hi, Autodesk consultant.
If the problem is the file, howcome the same file is correctly open by
DWG Trueview 2013?
Message 4 of 11
pendean
2013 is pathed to the fonts in use, 2017 is not? Post your DWG file, let's all have a look.
Message 5 of 11
docucenter
In the attached file, letters are overlapped.
Message 6 of 11
pendean
Not seeing anything wrong here
Message 7 of 11
docucenter
Did you open the file with DWG TRUEVIEW 2017? On my computer it looks like in the first attached file I've sent, with letters overlapped. What would be wrong?
Message 8 of 11
pendean
Message 9 of 11
docucenter
Hello, Dean.
The problem is that when I open the file, it looks like this:
Message 10 of 11
pendean
Nothing in your posted file looks remotely like your screenshot here: where is that screenshot actually from?
Why aren't you using the 2013 version if it still works?
Message 11 of 11
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
