Thank the help from Unattended DWG plotting and PDF publishing without AutoCAD. I just got the run PUBLISH in a script of DWG TrueView to generate PDF file. it works file.
Here is something I like to solve
1. when I run the bat:
"C:\Program Files\Autodesk\DWG TrueView 2015 - English\dwgviewr.exe" "c:\drawings\ sample.dwg" /b "c:\scripts\plotPDF.scr" /nologo
it will show DWG TrueView window and close it when it done. is there anyway I can hide it, like run it in command only mode?
2. when PDF is created, it will be open in Acrobat Reader. how I can turn it off?
3. Is there a log so I can troubleshooting if something wrong?
Wes
If you invoke the EXE file from a script (Windows script/batch file, not AutoCAD script), there are ways to launch an application in a minimized state. (Not tested for this case.)
Opening the PDF after publishing can be controlled through an option in your .pc3 file. And Plot LOGs in the Options.
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
Hi vladimir.michl:
I tried
start /MIN "C:\Program Files\Autodesk\DWG TrueView 2015 - English\dwgviewr.exe" "c:\drawings\ sample.dwg" /b "c:\scripts\plotPDF.scr" /nologo
It would just start TrueViewer, window popup, then stop there, no PDF puglished.
about opening PDF after publishing, beside pc3 file I found there is another place, in DSD file, [SheetSet Properties], ViewFile=FALSE
I tried both, still 1 pdf opened.
right now I tested with bat file. at the end I will move all to .net exe file
Any idea?
Wes
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
