I have quite a few drawings where I need to update the title block with a new version. Issue is all of these drawings are a different size from each other and the new title block.
Is there a way to replace the original block with the update but still keep the size of the original?
I have tried the replace-block command, but when I use that it blows the size up to way beyond what either block is. I also tried using the bre.isp program, but it also does the same, it replaces but scales it x10.
