DWG TrueView
Welcome to Autodesk’s DWG Trueview Forums. Share your knowledge, ask questions, and explore popular DWG Trueview topics.
Programmatically plot a file
1 REPLY 1
1537 Views, 1 Reply
Hello everyone,
I was looking to utilize .NET to simply plot a file (to PDF) with True View via Active X controls.  The only cavaet is the lack of AutoCAD; which shouldn't be needed, except the .pc3 file, correct?
Would the following code be reasonable once I reference the axAcCtrl.dll and select the Acctrl Component (which I do not know if I'll have access to...)?
string[] pArray = new string[0] {"D:\\Example.dwg"};
AcCtrl1.PutSourcePath(pArray)
axAcCtrl1.SetPc3File("DWG to PDF.pc3")
AxAcCtrl1.SilentPublish(pArray);
If it is clearly wrong, should I try using a different DWG viewer/plotter?  E.g. AutoDesk Design Review?
Thanks!
1 REPLY 1
banna.kbet
Hey,
Do you get any solution?
I am also running same problem...
please reply me if any possible solution.
regards
Banna
banna.kbet@gmail.com
